- 27 Nov 2009
Hi there!
Too many Full Tower cases can be found on market, but I wish ask You advice before spend grands for new PC.
There my own req.
1. Needs to be ALL quiet n isolated by rubber! Like I had old case, rubber isolations for screws (washers) where installed noisy parts -HDD, -motherboard, floppy, CD/DVD-drive, Power Supplies. All this parts needs to be screwed separately(with rubber washers), NON-direct-contact with case at all. Some small situation can do my self UPDATE as improvisation or buying enough cheap case updates but with fine quality of course.
2. Flow of fan, front in, back side out - turbine idea. No side or upside open area(if You have better ideas - let me know about it).
2.2 if will be needed upside or side to be opened (for temperature overheats) ill simply remove side lids. ^^
Will be great if have any good noisy isolated cases
Oh... my choose left behind
AMD -->, AMD Bulldozer FX-8 Eight Core 8150 Black Edition 3.60Ghz (Socket AM3+) and graphic card Radeon HD 7970 with PCI-Express 3.0
Have better ideas? - tell me please.
HDD 1st SSD with good write n read ability. Never had SSD but wish to try it.
Many thanks for future recommendations
There my own req.
let see pricing for it, maybe older processors will be bit grounded.
