cAse choosing
srry guys I didn't post this tread in CASE Sentral .My bad thanks again. If I tell I want a case that supports E-ATX and has removable mobo tray, side window. What can you suggest
I didn't read the spec or you didn't read the responses?
As four posts up, I recommend the akasa omega/mirage/eclipse with the optional side window. These are all e-atx compatible, have a removable motherboard tray and are fantastically well built.
Cheaper:
But you get what you pay for.
Ah good. I hope the above has helped you choose a case.
Always read several reviews of a case before buying to ensure it is what you are looking for, or you'll end up with one you don't like
The raven has a strange bottom to top airflow effort I believe, which unfortunately doesn't work very well.
I stand by the Akasa cases, I have the omega with a solid side panel. Couldn't be more pleased with it, most of the way through fitting radiators at the moment.
