In the middle of deciding parts still for my new build.
I quite like the look of the following towers but I need help in determining if the below cooler and graphics card would fit either of them or not:
- Bitfenix Shinobi XL Window
- Corsair Obsidian 650D
- Thermaltake Overseer RX-I
- Zalman MS800 Plus
- Zalman Z11 Plus
Compatibility check with:
- Corsair Hydro H105 Extreme Liquid Cooler
- Sapphire Radeon R9 280X Toxic OC 3072MB GDDR5
I have found a website called PC Part Picker UK which states what are compatible but I have my doubts for some reason so looking for some confirmations etc.
PS, as this is also the first water cooled setup I will be doing and although not a full custom setup, I have a question about coolers such as the H105. What do I need to do to install them? Do I need to fill them with any coolant or anything or is it simply mount it to the tower and install it over the processor like a regular heatsink?
Thanks all
- Zalman MS800 Plus
- Zalman Z11 Plus
Thanks all
