Case connectors
30 Aug 2006
Atm I am having a little trouble plugging the case plugs (power switch etc) into the motherboard (Asrock ConroeXFire-eSATA2)
Some of the plugs have 3 pins such as the power LED switch but in the motherboard manual it looks like this
1 2 3
0 0 0 (pins)
1 PLED+
2 PLED-
3 PWRBIN#
I am pretty sure the switch goes in with the letters of the switch facing downwards (when looking from the top) but I am not sure what PWRBIN means
Also I dont know where the power switch plugs into
I had trouble with mine on my new case.
What I did is get the old power switch and see which way they went, then did the same with the new leads.
PWRBIN may be for the reset switch?
