Case Conundrum
22 Sep 2009
I’m looking to upgrade my system but want to reduce the size of my case as I go to a fair number of LANs. By the looks of it I am looking at a small midi/mini tower that can take a full ATX motherboard. The only thing I’ve seen so far is this:
http://www.overclockers.co.uk/showproduct.php?prodid=CA-163-LL&groupid=701&catid=7&subcat=187
The concern I have is that I don’t want the PSU hanging out of the back of the case but looking at the numbers I don’t think I’d be able to get it inside the case without the CPU cooler getting in the way. I only use 1 DVD drive and at the most only 3 HDD’s although that’s probably going to go down to 2 shortly.
Does anyone have any suggestions?
Thanks
I know it sounds lik a daft thing to suggest but what about removing the wheels and poutting some castors on your current case?
If not I'd second the Scout or look at the Antec 200/300 if you're on a tighter budget
i think going for the scout would be better than jsut adding castors, i think with the scout you get a strap aswell what makes it easier to carry ( correct me if im wrong, iv only hearda about it )
