Case/Cooler size check...
14 Sep 2007
Limbo
I'm about to order the components for my new build, want to get the following case...
http://www.overclockers.co.uk/showproduct.php?prodid=CA-007-AD (case width is 207mm)
and the following cooler...
http://www.overclockers.co.uk/showproduct.php?prodid=HS-005-BQ (unmounted height is 166mm)
I've looked up the measurements on both and I think it should all fit, however is there anything obvious I might be missing? I'm just wondering if the noise dampening material will reduce the case width so significantly that the cooler wont fit.
I'm also unsure about how much width I lose with the mobo mountings and the CPU seating.
