Case & Cooler Upgrade
23 Oct 2004
Cardiff
Hi guys advice needed once again...
Current spec :-
E4300 @ 3Ghz (70c+ Orthos)
2Gb GeiL Value 6400 Ram
Asus P5N-E Sli
BFG 8800 GTS 320 @ 600/1800
Unfortunatley I have a crappy generic case with just the Intel stock cooler and one 60mm side fan for cooling, so time to upgrade this particular part of my spec.
For a new case I was thinking along the lines of the Akasa Eclipse or Mirage, am I right in saying the Eclipse comes with fans but the Mirage does not :confused:
And for a cooler I quite like the performance of the Noctua NH-U12F :D but unsure of the looks of it :( I like the look of the Akasa Evo120 with the Amber providing the case already came with some Ambers (Eclipse).
Finally would there be much room to fit a 3rd party heatsink(Noctua NC-U6/Thermalright HR-05) on the northbridge after installing either the Noctua/Akasa cpu cooler?
Cheers
paul_64l said:
i think the nocuta is smaller than the ninja and i have them on that board
Thats a very good sign, thanks.
begbo said:
Eclipse doesn't come with fans, not sure on the mirage though. Thought about the lian li pc7+?
Hmmm thats strange as on both the OcUK listing and Akasa spec page it says :-
OcUK = "- 12cm front and rear fans are included to provide maximum airflow and super silent operation"
Akasa = "Ventilation | 120 x 25mm fans in front & rear"
As for the PC7+ just looked at it now and it looks more plain/understated than the Eclipse and Mirage which I find plain as it is.
If the Eclipse definatley doesnt come with fans then I think the order will be for :-
Akasa Mirage
Noctua NH-U12F
Noctua NC-U6
Noctua NF-S12 1200RPM x2
Which I guess would make me a Noctua fan boy lol :D
One further thing would another Noctua NC-U6 fit ok on the southbridge if required considering the size of my gfx card and all other bits n bobs I would be adding?
*Edit* Just rang OcUK who said if it says it comes with the fans then it does :D Anyone bought one recently?
