Hi,
I've never really bothered with buying extra fans in my case or replacing the ones that came with the case, etc. Or anything to do with fans for that matter
so I am quite the novice when it comes to cooling.
Basically, my problem is noise. Even when idle, the PC is quite loud, under load while playing games etc, it can be very noisy. I'm pretty sure that most or all of the noise is coming from the graphics card, but the heat of it would be caused by the overall case cooling?
Nothing in my system is overclocked. Also might be worth mentioning that my PC seems to get very dusty quickly.
Pics of my setup below:
The case is an Antec P182 Midi Tower (I think), and the fans attached to the case are stock. The CPU cooler is an Akasa AK-CC4009EP01 Venom Pico Compact
I have a feeling that the CPU cooler is facing the wrong direction? Perhaps it should be facing downwards onto the graphics card.
So, any ideas how I can improve my fan setup to reduce noise and stop my graphics card sounding like an airplane taking off when under load? (be it replacement fans, extra fans, changing CPU cooler direction, etc)
Thanks
so I am quite the novice when it comes to cooling.Basically, my problem is noise. Even when idle, the PC is quite loud, under load while playing games etc, it can be very noisy. I'm pretty sure that most or all of the noise is coming from the graphics card, but the heat of it would be caused by the overall case cooling?
Thanks
