I'm looking for as close to silent as possible, how does this sound.
CM-690 - Already got
Fanless psu
NH-D14
DEMCiflex filters on the intakes
Fractal Design 120mm
Rear Exhaust
Fractal Design 140mm
Top Exhaust - Rear possition
Front Intake
Bottom Intake
Side Intake - Bottom possition
Tape Up
Side - Top possition ( D14 will block this off I think )
Other side (80mm)
So 3 intake, 2 exhaust, 4 x 140mm and 1 x 120mm. Should give possitive pressure and sufficient airflow for the psu.
I use onboard graphics so the only PCI card being used is my TV card. Atm it'll be cooling my athlon2 620 and I'll be upgrading to either Phenom x6, SandyBridge or Bulldoser as soon as it's clear where Bulldoser sits.
Fanless psu
NH-D14
Rear Exhaust
Front Intake
Bottom Intake
Tape Up
Other side (80mm)
