Case + Cpu cooler
31 May 2009
Im going to be buying a cpu cooler and case within the next week and was wondering what you guys thought.
Cpu Cooler - For i5 750, hoping to overclock to 4.0Ghz
http://www.overclockers.co.uk/showproduct.php?prodid=HS-005-AN&groupid=701&catid=57&subcat=1395
http://www.overclockers.co.uk/showproduct.php?prodid=BU-035-OP&groupid=701&catid=57&subcat=1395
http://www.overclockers.co.uk/showproduct.php?prodid=HS-072-AK&tool=3
http://www.overclockers.co.uk/showproduct.php?prodid=HS-002-CS
One of these, not sure which one yet
Case
http://www.overclockers.co.uk/showproduct.php?prodid=CA-135-AN&groupid=701&catid=7&subcat=160
http://www.overclockers.co.uk/showproduct.php?prodid=CA-011-FD
http://www.overclockers.co.uk/showproduct.php?prodid=CA-237-CM&groupid=701&catid=7&subcat=29
In the same boat for these. Was tempted by the Define XL due to its 'noise absorbing material' as my GTX 570 can get pretty noisy under load.
A friend of mine found a DarkFleet DF85 for £105 on another site which is rather tempting imo, and the HAF 932 was suggested by him aswell as he currently owns one.
If anyone has any suggestions they would be much appreciated :)
The case choice is upto you, nether of them are bad/rubbish, your the one having to look at it day after day.
As for the cooler, do you have RAM with tall heatsinks on them like Gskill ripjaw/Corsair Vengeance?
If you're considering spending £50+ on cooling i would consider the Silver Arrow - link.
It has great results and reviews (out performing the links) and will run very quietly.
No they're just the standard size so they shouldnt be in the way.
The Silver Arrow does look rather good, i'll have a think about that one.
silver arrow is pretty much the best air cooler around, and since you have standard sized heatsinks on the ram it will fit in any of those cases
