- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Hi guys.
I thought I would post the great deals OcUK have running at the moment.
Antec P100 Mid Tower Silenced Computing Case @ £59.99 inc VAT
The P100 is an ATX case that epitomizes cool, quiet, and sophistication. It features Antec’s award winning the Performance One series design and Quiet Computing™ technologies that minimize system noise.
In addition to 7 expansion slots, the P100 also supports 2 toolless 5.25” drives and 7 tool-less 3.5”/ 2.5” drives. With a greatprice to feature ratio the P100 is the only economical case that delivers first class silence performance. A balance of price and feature is achieved by integrating Antec design with superior build quality. Engineered with Quiet Computing™ Technology, the P100 is truly in a class all its own.
Features:-
- Compatible with up to 3-way NVIDIA SLI/AMD CrossFireX.
- Complete dual layer design: steel and foam panels deaden noise.
- Grommet-lined cable routing holes with 20mm of space behind the motherboard
tray
- 2 front panel USB3.0 ports
- 7 quiet 3.5h/ 2.5h drive bays utilize trays with preinstalled silicone grommets
- 2 tool-less 5.25h drive bays
- Advance cooling solutions with top mounts spaced for 240mm radiators
- Includes two silent 120mm fans with fluid dynamic bearings
- PSU intake & front air filters
- Advanced cooling system: includes 2 fans and 3 additional fan mounts
- Sleek front bezel with double-hinged door: open up to 270 .
Specification:-
- Product Name: P100
- Model: AQP100BA
- Form Factor: Mid Tower
- Motherboard Support: ATX, Micro ATX, Mini-ITX
- Material Syntheticmaterial and 0.6mm Steel plate combination
- Expansion Slot: 7
- Dust Filter(s) 1 x front + 1 x bottom
- Max CPU cooler height . 6.7h / 170 mm
Drive Bays
- 2 x 5.25" tool-less
- 7 x 3.5" / 2.5h tool-less HDD bays
Cooling
- 1x 120/140mm Front intake fan
- 2x 120/140mm Top exhust fan mounts
- 1x 120mm rear exhaust fan mounts
Included Fans
- 1 x 120mm Front FDB fan, 1200 r.p.m 18dB(A)
- 1 x 120mm Rear FDB fan, 1200 r.p.m 18dB(A)
I / O Ports
- 2 x USB 3.0
- 2 x USB 2.0
- 1 x Audio I/O ( AC97 & HD Audio)
- PSU mounts ATX/ EPS standard
- Cable Management Extra large cable routing space …20mm
- Dimensions (H*W*D) 484 * 220 * 523 (mm)
WAS £74.99 inc VAT.
BUY NOW @ £59.99 inc VAT
Antec P280 Super Midi Tower Case - Gun Metal Black @ £79.99 inc VAT
The Antec P280 epitomizes cooling, quiet and sophistication. The durable polycarbonate layer prefitted deadens any noise and ensures Quiet Computing™. The P280 also boasts an new all black interior for a new updated feel from the older P180. . Additional features include two internal 2.5" SSD bays, and a mountain of 3.5" bays, excellent cable management and a special gunmetal gray finish for one-of-a-kind style.
- Supports up to XL-ATX Motherboards
- 9 Expansions Slots
- Quad GPU Support
- 6 Cable Routing Holes
- Bottom PSU mount with dedicated air filter
- Maximum Size CPU cutout
- Suipports GPUs up to 330mm long
- Top Power/Reset Buttons
- Front I/O Ports: 2 x Audio / 2 x USB3.0 / 2 x USB2.0
- 3 x 5.25" Drive Bays
- 2 x 2.5" Drive Bays
- 6 x 2.5" Drive Bays
- Top Cooling: 2 x 120mm TwoCool Fans
- Rear Cooling: 1 x 120mm TwoCool Fans
- Front Cooling: 4 x 120mm Fans (optional)
- Removable filters on PSU intake and front intakes
WAS £99.95 inc VAT.
BUY NOW @ £79.99 inc VAT
Features:-
tray
Specification:-
- Model: AQP100BA
- Expansion Slot: 7
Drive Bays
Cooling
Included Fans
I / O Ports
- 2 x USB 3.0
- 2 x USB 2.0
WAS £74.99 inc VAT.
- Quad GPU Support
WAS £99.95 inc VAT.
