case decision made easy by OcUK staff
23 May 2004
staffordshire
just wanna give out a thank you to Andy at OcUK for helping me make the right decision regarding the Antec 900.
I was a little concerned about the four pin connector fitting the top of the mobo as the psu sat at the bottom, no probs for Andy tho, he sorted me out with an extension lead just in case.
he promised me a 8-10 degree drop in temps, well im happy to report a 10 degree drop !
i'd say anyone who isnt sure about choosing this case, dont be , its outstanding.....failing that "ask andy" he'll soon put you straight !.
cheers mate.
A lot of similar designed cases come WITH extension cables for motherboard power, PC-A10 is a good example.
What was your old case, as saying you got a 10C drop is meaningless unless you tell us what you upgraded FROM.
Glad you are satisfied with your Antec 900, not exactly my type of case, though its not bad for its price range, and gets good reviews form people here.
to be honest with you, i dont really know tbh.
it was a big silver thing with wheels, also had a blue temp lcd and a blowhole at the top.
it was def a "no-make" tho.
..got it from clockers about 2-3 year ago.
