The h100 will not fit in the Raven unless you put it at the bottom but this then means you will loose the benefits of the large predetor fans at the bottom.
I have the raven 2 and use a h80 on my 2500k and it runs really nice.
If the h100 is a must then the raven is a no go really.
I believe so, bit of a pain but it's a fantastic case.
By the way, do you have the H100 already?
Just that a high end air cooler will perform similarly with a little less noise whilst costing less, but will of course take up a lot of space and may have issues with RAM heatspreaders.
If you go for a normal cooler I'd be inclined to recommend the Raven due to its superior air cooling abilities. That's not saying the Corsair is a bad case before the fan boys flame me.
The NZXT Phantom is a good call, nice case to work with the fascia is a bit plasticy but it does all feel of quality. I'm also fairly sure you can put a 360 radiator in the roof as it has a similar setup to the ATCS 840 (2x 220mm fans).
