Case decision
8 Sep 2012
I am currently in the process of putting together a new build and I have to decide on a case! I had all but decided on-
Corsair Obsidian 650D Gaming Midi Tower - Black [CC650DW]
But I was just thinking is there an alternative that may free up some cash to put else where?
I'm looking to get the Corsair Hydro H100 so really want a case that can accommodate the 120x240mm rad in the roof.
I like the look of these also-
Cooler Master CM-690 II Advanced USB3.0 Dominator Case - Black [RC-692A-KKN5]
Cooler Master CM-690 II Advanced USB3.0 Windowed Dominator Case - Black [RC-692A-KWN5]
Fractal Design Define R4 Midi Tower Case - Black Pearl [FD-CA-DEF-R4-BL]
Zalman Z11 Plus Midi Tower Gaming Case - Black [Z11 PLUS]
Any opinions/ideas would be most appreciated.
Many thanks
Nick
From personal experience of the R3, the fractal cases are good cases.
If you ever plan on going full water cooling though then the CM-690 would be a better choice.
sure, if you want to fit the h100 on the roof, then omit the mobo. if you want to fit it in the front, i dont think the tubes are long enough.
edit: guess ttl was wrong, the r4 will fit the h100 at the top, if the mobo doesnt have large vrm heatsinks. and only if the h100 is in push or pull config. cant have push+pull h100
http://i.imgur.com/hcMN8.jpg
Actually really liking the look of the R4 and now I have pretty much decided against a H100 and will get something along the lines of the noctua I think it will be a better choice :D
