Case Dilema
22 Mar 2014
Plymouth
Hi there guys can you help me pick a case I dont know what to pick?
1. Cooler Master Strom Trooper with window (BLACK)
2. NZXT Phantom 530
3. NZXT H440
4. Phanteks etheno Luxe
my specs are:
I7 4770k
h100i
z87gd65
corsair ax760
aquaero 6 pro
gtx 780 sc acx
Was going to go for the luxe but decided to go h440 instead as much quieter and I wasn't bothered about restrictive air flow as I don't plan to OC
what is the diffrence between pro and luxh as they look similar I would say
Just a couple of extra features
e.g.
- LED Strips
- Better looks (front panel over the front dust filter)
- More SSD brackets I think?
Just a bit more rounded overall, both are really really good cases
Do you know anything about 780t? It looks good to me but im not sure about its build quality as it says it's mostly plastic and I wonder what kind of quality is it?
At the same time these are my components and I dont know if i should go for white or black case. What you think?
I have no idea about the 780T quality, it should be okay as it's Corsair
Wow those colours are bad, yellow and green :D I'd go for black but then again I'd never get a white case, it's subjective so entirely your decision on that
I'ts not yellow it's more like light green real life. Entire thing is fluorescent and glows under uv light. Also thanks for help. But now I need to decide between 780t and luxe
