-Case Dilemma- Aerocool DS200
22 Jan 2013
England
Just a quick question regarding this case-
https://www.overclockers.co.uk/aerocool-ds200-black-white-edition-ca-095-ae.html
Im pondering getting this case for a Black/White build Im planning on putting together.
Question is does anybody know if this cooler will fit in a push-pull config-
https://www.overclockers.co.uk/cors...iquid-cpu-cooler-cw-9060021-ww-hs-032-cs.html
I obviously I would be needing 2 extra 120mm fans so Im looking at these-
https://www.overclockers.co.uk/cors...tion-dual-pack-co-9050016-wled-fg-026-cs.html
I will be going with one of these M/Boards(aint decided yet,different sockets=different CPU(£'s)-
https://www.overclockers.co.uk/msi-...cket-1150-ddr3-atx-motherboard-mb-279-ms.html
https://www.overclockers.co.uk/msi-...cket-1151-ddr4-atx-motherboard-mb-307-ms.html
https://www.overclockers.co.uk/msi-...cket-2011-ddr4-atx-motherboard-mb-300-ms.html
Id be grateful for some info/help from you lads before I go ahead and place the order.
Cheers--
also don't buy the corsair af120 fans for a radiator, you need the sp120 fans. As for not needing on that setup, would depend on what CPU/overclock the OP would be running...
I have Phanteks MP fans cooling a H100i. They are good and black and white.
On another rig I used Aerocool DS Editions to cool a H105. They are also good and have a black and white version (white leds). The non-PWM didn't hurt them, motherboard was able to control RPM through voltage and they were quiet at full 12v anyway.
