Hi Guys,
I’m in a bit of a dilemma? I’ve been waiting for the HP Omen Obelisk which has just hit the market, the 8700 with 2080 graphics card. I wanted to buy it but in America it was on sale for $1500, here its £1900. Furthermore I really don’t like the holes on the top of the case, as my room is a dust magnet!! Ideally I would like a case with amazing thermals and quiet as possible and with as few holes as possible!!
So now I’m looking into rather than buying....., building one or getting a pc built. My budget is £2k max, cheaper the better obviously. I don’t want to go water cooled as I personally think it’s too dangerous. Therefore I will be looking at an air cooled system. I am hoping for an Intel based 8700k + 2080 or 2080Ti, Z390 motherboard, 32gb ram. I want a high end performance pc so I don’t have to upgrade for a loooong time. Btw I don’t game! I love tempered glass and RGB, how much does this affect thermals though?
I have been looking at some cases and have narrowed it down to these: -
1. BeQuiet - DARK BASE 700
2. Enthoo Evolv X Glass
3. Coolermaster MC500mt
4. Lian Li - pc-o11-wgx-rog-edition
5. Fractal design define s2 --- OR --- R6 USB C
Any recommendations – pros and cons on the above cases or other parts I should use?
Is it possible to build what I’m looking for under £2k?
Any advice is much appreciated.
Go for a decent quality case that you like the look of and get some good quiet fans for it, with more fans as intake than outtake you will create positive pressure that will force air out of the case and stop dust from creeping in.
