Case Fan Control - Help
24 Jun 2011
Sheffield
Had this system build for me by OcUK.
4690k
Corsair H60 V2
Gigabyte Z97X-SLI
Inside a Corsair 450D which has 2 x 140MM Fans intake running at 800RPM
Now, How can I vary the RPM of these fans without using the BIOS.
CPU Cooler increases and decrease fan speed on temp which I assume so do my intake fans as they are perhaps hooked up to the motherboard, Temps aren't an issue but out of curiosity I'd like to be able to alter my case fans speed.
Will they be on an automated profile? Temps haven't been high enough to alter the speed they run at as of yet.
If they're connected to the board and 4 pin they'll be PWM and only ramp up when they need to.
If you want to do it manually, you'll need a fan controller. Just disconnect them from the board and up to the fan controller.
Gotcha.
Thanks for clearing that up.
