Case Fan Controller
Look at the ones that go deeper into the bay.
Lamptron ones, for example, are great devices but often don't reach far back enough (depending on your locking mechanism) and require the little screws.
Worth noting, however, that many will still want screwing in from the opposite side anyway, to keep them from twisting.
Decide which is more important.
Thereafter, it's down to whether you want touchscreen, physical dials or plain PWM box, plain or display screen, just a fan-con or a multi-function panel with card reader and USB3.0 as well, what colour you want, etc etc...
I like the Lamptron ones (the FC5 v3 is great) and things like the Thermaltake Commander F6 myself...
