Case Fan Controllers
8 Oct 2010
UK - North East
Im planning on buying a case fan controller, I only have 4 fans in my case, have 3 working and 1 I need to buy an adapter for, so I thought why not get a controller, so I can make it quiter and also get all 4 connected.
Now I am just wondering about wiring issues, as im not to sure my back fan wire will connect all the way to the front of the case, and wont this make it took a bit dangley, and non neat etc?
How excatly do I connect the fans to the controller?
Easy enough to connect the fans to the controller but it's another thing trying to route the cables. lol ! Most of your time will be spent on cable management as connecting the fans takes seconds. Easy enough but just take your time and use some cable ties along with a little imagination.
most decent controllers come with extentions.
my lamptron FC2 did. i know a lot of the schythe ones do too
