I would appreciate some advice on choosing and connecting case fans for a M-ATX computer I'm building (120mm front intake fan & 92mm rear extract fan).
Previously when I've built computers, I've always wired the case fans directly to the power supply via the Molex connectors, so that the case fans are always on and always running at full speed. However, my motherboard for this build (Gigabyte GA-Z97M-D3H) provides three 4-pin system fan headers. I assume these headers will allow me to fit either 3-pin case fans, or 4-pin PWM case fans - but which to choose?
Presumably if I fit 4-pin PWM case fans to the motherboard system fan headers, the fans will be speed-controlled by the motherboard using Pulse Width Modulation control (the same speed control as is used for the CPU cooling fan)?
And if I fit 3-pin case fans to the 4-pin motherboard system fan headers (and assuming I can change the mode of operation for the system fan headers in the BIOS), the fans will be speed controlled using a feedback loop that varies the applied voltage to alter the fan speed?
Another thought (as negative pressure cooling is generally considered preferable to positive pressure), would be to always run the 92mm rear extract fan at full speed, but allow the 120mm front intake fan to be speed controlled. Note that the CPU cooler fan will also be tending to operate as an intake fan, as it is located directly in front of the (unused) case side panel intake grille. I think having the rear extract fan always running at full speed would tend to bias the case cooling system towards negative pressure, unless/until the front intake/CPU fans were cranked up by their motherboard speed controls.
So, considering the two modes of case fan speed control available, which would you recommend I use, 3-pin variable voltage or 4-pin PWM?
And why?
Would always running the rear extract fan at full speed be a good idea?
So many questions!
Thanks.
BTW, I intend buying Be Quiet Silent Wings 2 case fans.
And why?
So many questions!
Thanks.
