Case fan/cooler placement
12 Jun 2019
Quick and hopefully not to stupid question!
I'll be having a gaming pc built by OC next month.
If the case comes with 4 fans (3 front and 1 rear) and has space for 2 fans on the top, will the cooler I order be fitted in one of the two top free spaces or will it replace one of the existing four fans?
Wasn't sure how important the coolers placement would be for effectiveness.
Thank you.
The top would be good. Either take the heat out the top or the back.
I think it's generally considered good practice to have more in fans than out fans to create a vacuum.
