case fan help please <3
11 Mar 2009
i just bought a noctua nf-r8 80mm case fan and would like to know if it will cool my computer enough without messing with the speed settings.
my specs are -
Gigabyte P35-S3G mobo
Intel E2180 2.00 Ghz
BFG Geforce 8800GT OC
Asus Vento A8 Case
2gig ram @ 667
You have one case fan?
Use speedfan to determine what temps your system is. Then post the results.. This will give you a good idea on how effective yor cooling is.
You've only got a E2180 cpu and not overclocked, it's not going to be putting out a lot of heat, unless your computer is in a sealed box I doubt temps are a problem.
my gpu is 57c
temp1 is 39c
temp2:-2c
temp 3:36c
hdo:29c
core0:32c
core 1:32c
core: 57c
ambient: 40c
Are these idle temps?
If not try running some heavy applications like CPC benchmarks, Orthos Prime or 3dmark 06.. and monitor the temps in the same way.
