case fan help
18 May 2012
For my new gaming PC how many fans would be needed in the case to cool these specs and what size?
Intel i7 3770k overclocked
Asus P8Z77-V PRO Intel Z77 (Socket 1155) DDR3 Motherboard
Corsair Vengeance Low Profile 16GB
KFA2 GeForce GTX 680 LTD OC
Seagate Barracuda 7200RPM 1TB
Intel 330 120Gb SSD
DVD RW drive
Creative Sound Blaster Recon3D Fatal1ty Professional Soundcard
750 Watt PSU
Cooler-Prolimatech Genesis Mega CPU Cooler
P.S a depending on the amount of fans recommended, a recommended case would be great.
thanks
Fan question without case known is foolish.
Very strange choice of CPU cooler...
Presuming the specs of both are right...
Silverstone RV03 is one of the best out there with regards to cooling. (No after market fans required)
Otherwise try the CM Storm Trooper, although I'd probably put some extra fans in there,
If you want to stretch the budget above the £100 or so that buys those two, then for around £200 get the Silverstone FT02. Best air cooling case around (again no need to replace the fans.)
kd
