So I have the Corsair Graphite 600T case shown here: http://www.overclockers.co.uk/showproduct.php?prodid=CA-071-CS
Recently the big fan on the top is having issues. Sometimes it doesn't run at all, no light and no spin. In this case I get go into my case and give the blades a push and it'll sort of start but be very weak, and then dies out after a few seconds.
Other times it will run, but it's as if there's a problem with the power to it, as the brightness of the light (and presumably the fan speed) gets dimmer and brighter every so often, as if the power going to it hiccups and lessens.
I've checked the connection and it's not loose or anything.
All the other fans are fine.
Any ideas on what could be wrong?
Thanks.
Thanks.
