IDIOT... IDIOT... IDIOT... !!!!!!
Sorry, but you did say...
It could be a perfect spot for my res but unsure whether sensible or not?
Depends what res you have.
EKWB have a number of funky res mounting options, including a fan one - Affixes to/behind/through a fan or fan mounting point.
So you could have the res inside and the fan outside, pulling in exhaust, with the screws going through the mount, case and then into the fan itself. Bit fiddly to make alterations perhaps, but it'd work.
I have case, then fan outside, then 120mm rad, with w/c tubes going back inside the case. However, it's a small Corsair 500R and that was the only way to mount both fan and such an oversized rad - Any other point or configuration was just that annoyingly little bit too tight!
Could be a case of suck it and see. If your temps improve and your noise is not significantly greater, then go with it.
^This, pretty much.
In theory, the whole positive pressure thing works, but there are so many variables between individual builds that could affect things, some quite noticably.
For example, I have 2 front intakes, 2 top exhausts and one rear exhaust. All exhausts vent through w/c rads.
I also found a lot of air was wasted because it tumbled around the HDD cage, GPU and even off some cables, instead of circulating nicely around the case like the diagrams said.
However, I get better temps with the added 2 intakes on the side panel, not through positive pressure, but because they're focussed directly onto things like the RAM and VRM/heatsinks.
Certainly try it, swap different fan types around (if you have different case, airflow, SP and so on), maybe have all intaking like some do, or even all exhausting.
It's kind-of an exact science, but one we can only be very vague with... Most people would swear my setup is ridiculous, and yet I consider 25ºC internal temp to be unusually high!
