case fan noise and filter problems
8 Jul 2010
Hi all
i brought a Xigmatek XLF-F1455 yesturday and im trying to mount it to my side case, i fitted it but its very noisy, im leading this to be that the fan is sucking air in too close to the holes and is causing extra noise. im using it an intake fa
How would this be solved? also where the best place to put the filter to stop dust coming? and what should i use
