Out of interest.... I've seen a few things about air pressure of fans etc, and was curious about placement of case fans for optimal airflow and reduced noise...
My thoughts are:
Having input fans at the front of the case pushed up against dust meshes and grills etc creates additional noise through turbulence and air being forced over the extra surfaces and, from the very little I understand about it, a low pressure fan may have trouble sucking air through these materials... ?
Therefore would it be better to offset the fan back into the case by an inch or 2 to allow air to be freely pulled through the fan (air would partly be from inside the case, but mostly from the outside) and just allow a natural suction of air through the dust meshes that would be created by the pressure of the fan a short way inside.
I've done some very rudimentary tests and having a mesh in front of a fan does appear to increase noise and cuts the air flow more than if i hold the fan a short way away from the mesh... but i havent done any temp monitoring or actually fixed the fan in position to test.
Just curious about what other people have found and any info or tips about air pressure etc.
I have a p182 case, thats already pretty quiet, but am thinking about replacing the 120 fan I have suspended in the drive bay with a 140 fan and replacing some of the tricools with a higher air flow but quieter option. (Noctua NF-S12B FLX, maybe sharkoon golfballs, or asaka ambers).
My thoughts are:
