Hi there,
I have 5 case fans in my system, can someone answer the following:
1. One of my fans at the front of my system (Yate Loon LED), is dimmer than the other fan I have. The brighter one has its own independant power from the PSU whilst the dimmer one is shared to another fan. Is this what is causing the brightness issue?
2. I had trouble trying to get all the fans to reach the PSU so I used the AUX fan slots on the motherboard. One of my fans wouldn't reach the PSU or an AUX so the only option was the Northbridge fan slot which wasn't occupied as I have an Abit AB9 Pro which uses a heatpipe cooling system. Is this safe to carry on using?
Many thanks for any help with these questions
Seriously though, if the motherboard uses a heatpipe system for the northbridge then the fan header next to it would have been intended to be used by a normal fan. It should be fine.
