I've been contemplating getting a new case for my Aorus Z370 Gaming 5 motherboard. The one I've been most interested in is the Cooler Master H500p mesh white
https://www.google.com/amp/s/www.overclockers.co.uk/coolermaster-mastercase-h500p-mesh-white-midi-tower-rgb-gaming-case-white-tempered-glass-ca-36u-cm.html?template=amp
which is roughly the same size as my aging Cooler Master Haf 922, but also I've been thinking of getting some RGB fans for my existing case but not 100% sure about the connection terminals.
So OCUK sell this 200mm RGB fan which I would get 3 of
https://www.overclockers.co.uk/raijintek-anemi-20-rgb-rbw-led-fan-200mm-fg-01t-rt.html
One front, one side and one top, but looking at the description the fan has a 3 pin connector but my motherboard has the following connectors...
Fans
So basically could I plug in the 3 pin fans to my motherboards 4 pin system fan headers and still use RGB fusion?
Fans
- 8x 4-pin Fan Header
- 2x Digital LED Strip Header
- 2x RGB Header
- 1x TPM Header
