Case Fan Recommendations
6 Dec 2005
Hey all,
I have just bought a TT Soprano case and I want to put some Blue LED Case fans (2 x120mm and 1x90) in it. I want to have the Ideal situation of quiet but being able to push nice amounts of air.
What fans do everyone recommend I should look at?
Thanks for the advice. :D
Phill
Silent fans with blue led's don't really exist, you will need to under volt them a bit using a fan controller of some sort.
I'd recomend to buy your led's separately, and use a nexus or akasa amber fan, as those are quiet and move an adequate anount of air. The nexus fans are the kings of quiet cooling.
