Morning all,
I'm looking at buying a bunch of case fans but not sure what to go for.
I think I'll be getting a Lian Li Lancool one or the Lancool two when it releases in November.
I want to make it flow as good as possible so I'm thinking:
3 fans at the front (Intake)
2/3 fans on the roof of the case (Exhaust)
2 fans on on the floor (Intake)
1 fan at rear (exhaust)
So I guess looking at 9 fans in total. I may not fit them all though and have one or two as a backup.
Any recommendations or opinions on my plan?
Edit to add: Not fussed at all about RGB.
Just make sure it's just a simple hub that splits PWM signal and uses PSU power .. might want to check power plug id Molex or SATA to match on what your PSU has.
