- 6 Dec 2007
- Cambridge
Hi everyone
I've got a bit of a tricky case to cool and could do with some help.
I use a Jonsbo UMX 4 Pro, which looks great but is really challenging to keep cool, as the front is a solid sheet of aluminium (so no front intake).
(not mine, but you get the idea)
Through a lot of trial and error, I've discovered that the best setup is:
I've tried a tower cooler for the CPU, but that pushed case temps through the roof.
I've gone with Noctua NF-S12B redux PWM fans for the intakes (the 1200rpm version). All the fans have dust filters and the case is on carpet. CPU temps are absolutely fine (it's a stock 3700x, so a 240mm radiator is overkill anyway), but the GPU can still get a bit warm.
I suspect the problem is the dust filters, which have to stay. Does the NF-S12B play nicely with dust filters, or should I look for something else? I want to keep the noise down, so I'd prefer something <18dB. Would the Silent Wings 3 be a better bet?
Thanks!
- 2x 120mm fans in the bottom as intakes (feeding the GPU),
- 120mm rear intake (so the CPU isn't just cooled with recycled air from the GPU),
- a top-mounted H100i as an exhaust.
Thanks!
