Case fan(s)
26 Dec 2005
Liverpool
Stupid question time. I will be adding another case fan to the rear of the PC but am a bit stumped as to where to connect the lead. I have looked at the motherboard layout and the only empty fan connectors are two Power Supply Fan connectors and one System Fan connector.
Any idea which connector I use?
I have had no experience adding anykind of hardware to a PC before so thanks in advance for any responses.
If the fan is a 3pin connnector then it would go into a socket on the motherboard called something like CASEFAN1. Failing that you could just buy a fan that connects to a molex cable coming out of your PSU.
