All this will be going into a Fractal Design Define R4 case.
YOUR BASKET
1 x Sapphire HD 7970 VAPOR-X GHZ 3072MB GDDR5 PCI-Express Graphics Card with FREE OcUK Ultimate Games Bundle £379.99
1 x Intel Core i5-3570K 3.40GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail £179.99
1 x Samsung 128GB SSD 840 PRO SATA 6Gb/s Basic - (MZ-7PD128BW) £119.99
1 x Gigabyte Z77X-D3H Intel Z77 (Socket 1155) DDR3 Motherboard £112.99
1 x Corsair Hydro H70 Core CPU Watercooler (Socket Intel LGA1155/LGA1156/LGA1366/LGA2011/AMD AM2/AM3/FM1) £58.99
1 x Patriot Viper "Black Mamba" Generation 3 8GB (2x4GB) DDR3 PC3-15000C9 1866MHz Dual Channel Kit (PV38G186C9K) £39.95
1 x XFX 850W XXX Edition Modular '80 Plus Silver' Power Supply £99.98
Have I got the fan setup about right? I'm hoping to keep a balance between noise/cooling as I do plan to OC. I plan to use 4 fans aswell as the H70 set to exhaust. There are 2 more fan slots spare should they be needed.
Anyone any experience with CLC and whether it's better to have fans set up to intake or exhaust?
Which fans would you recommend as the standard fans are 2 x 140mm Silent Series R2 fans.
Thanks for looking
YOUR BASKET
Thanks for looking
