Case fan too loud
18 May 2011
Hi guys
well i got all my parts today
built it and all is running good
i decided to put a case fan in for extra cooling
however the thing is running at full wack and is properly loud lol
Ive tried using speedfan and it wont turn it down and cant seem to find anything in the bios either to turn it down
oh and its plugged on the motherboard. 3 pin connector i believe
any ideas?
thanks
I have always found easier to use a fan speed controller or a speed reduction cables rather than realying on software.
Not all motherboard headers are controllable Via speedfan or similar. Check your manual which allow control and use them. If not then you'll need a fan controller of some kind, or the 7v trick, or a suitable resistor, or get a fan that will be quiet enough at full speed.
Yeh must admit in my experience Fan Controllers are the way to go for sorting the
speed of fans out must more reliable that software.
On the lookout myself for a cheap fan controller,only need it to reduce the speed of 2 case fans.The fans are 3 pin connections btw.Will watch this thread for any good suggestions.
