- 26 Jan 2009
- Amsterdam
I realised that my Coolermaster 335 case didn't come with a fan at the front as some of them supposedly did. I had a couple of what I believe are 80mm (they might be 60mm, anyway) fans, so I thought I might as well put one in.
The fan has two molex plugs - a 4 pin input, and a 4 pin output. I can only assume that you plug in a molex from the power supply and can then daisy chain this to other devices such as IDE hard drives.
However, this fan also came with a 3 pin adaptor for plugging into the motherboard directly. The adaptor also has a 4 pin input and a 4 pin output molex plug. Do I match both ends to the corresponding ends on the fan wiring, or what?
