fractal design 92mm fan with a molex to 4 pin cable if its needed would be my recommendation
can you provide a link please mate
thank you
thats the one gary
heres a couple of cables to use (not sure which you will need)
4 pin molex -> 4x 3 pin fans:
4 pin molex + power managed fan output -> 3x 4 pin power managed fans
(doesnt take power from the motherboard, only uses the variation in power to control the speed of the fans
never used them before unfortunatly.
what needs to be 15mm thick? i assume its not the wires
