Case fans... a bit of modding?
23 Sep 2008
Hey my computer is a mesh, using a coolermaster Mystique case, alim with wavy front panel. My Case
It has a 2 fans as standard one on front, exhaust on back. It has an option for a 80mm side fan over the CPU so i have nought one for that mount point.
Underneath this there is a Vent, about 90x90 that is directly over the GFX card, there are no mounting holes for a fan there though...... Now can i get a fan and just screw it into the vent holes? I doubt the would align.
I thought of just getting some superglue and glueing it to the case, being carful not too freezet the fan up. Maybe some double sided tape?
I am going to upgrade the case, but not got the money right now, wereas a fan will cost me about a fiver and help my system a lot. perhaps with a pci blower as well. (i planning on xfire 4850s).
