Hi guys,
I recently purchased a CIT Vantage type-r case which has 4 Molex fans in it.
They are kinda quiet, but when idling they were a little too loud so I decided to get a fan controller.
The only molex controller I could find was the Aerocool F6XT.
Having installed it, there is a problem. When I adjust the fan speeds, which are in steps 1 2 and 3, at 1 and 2, there is a loud buzzing from the fans. It is like a robotic noise and it changes in pitch depending on setting 1 or 2.
Is there any solution to this? or do I have to send it back.
Thanks,
Chris
Thanks,
Chris
