Case Fans and LED's
16 Feb 2014
Hey, I currently have the NZXT Phantom 820 case, it comes with build in LED's which can be controlled and had their color changed. Is there a simple way to buy more of the same LED's and a Fan with transparent plastic, so I can have fans with the leds that change color with the rest of the case?
I hope that makes sense. So something like:
Cooler Master Mega Flow 200mm Transparent Blue
And then my new colour changing LED's and replace the blue ones in the above fan with them, and split the cable in the colour controller for the extra fan?
What are the LED's I would be looking for?
