Case Fans & CPU Cooler Questions
19 Mar 2008
Hi all,
I've got an Antec Sonata II case with an AMD Athlon 6000+ cpu on it. The cpu has the standard heatsink on and it's been getting quite hot, up to 60* playing games and I can only imagine it's going to be getting worse as the summer months go on. What is a good upgrade to the heatsink on the cpu to bring that down a bit?
I'll be putting an 8800GT in it shortly, so is it worthwhile replacing the Antec Tri-Cool on the back with something better, like a yate loon and also adding another one in the front of the case and adding a fan controller to help with the temperatures?
I haven't overclocked anything in it, so it's more really how to bring the temps down a bit without having to spend a fortune. Probably not wanting to spend much more than £50 on the parts, but I can go higher if needed.
Thanks!
Artic Freezer pro if you want value for money and will enable to overclock as well if you want.
http://www.overclockers.co.uk/showp...64 Pro PWM CPU Cooler (Socket 754/939/940/AM2)
Tuniq tower if you want one of the best and are going to overclock to the max.
http://www.overclockers.co.uk/showp...CPU Cooler (Socket 478/754/939/940/AM2/LGA775)
Make sure you have good airflow in the case and your cables are tidy.
If you haven't already got a front fan then that will make a big difference. My amd rig had one at the front in front of the hard drives and one at the back near the cpu and kept a good airflow flowing through the case.
I had them on a fan controller which meant that i could have them quiet but put them up when gaming/hot summer months.
Just had a scooch around the OC shop and I'm thinking:
Akasa AK FC-06BK Fan Controller Junior - Black £7.99
Yate Loon D12SL-12 120mm Case Fan - 3 Pin £3.99
Arctic Cooling Freezer 64 Pro PWM CPU Cooler (Socket 754/939/940/AM2)
What about fan controllers, I'm tempted with the Akasa as it's quite cheap and I don't really need it to do much, but is it worth spending more on it?
That will be fine. The more expensive controllers bring in displays with rpm readouts and temperature probes (My asaka has these) but I never really look at them since all infor can be found in windows with coretemp, everest etc.
Also some high end controllers have alarms and automatic fan speed increases to match increases in temperatures.
One last feature you get with only a few expensive ones is the ability to switch off each fan totally - basic fan controllers only vary the voltage to the fans from 5v or 7v to 12v.
So not worth spending any more money unless you need any of those features.
All I ever did with mine was turn the knob until I couldn't hear the fan anymore for surfing etc and then put it on full, if and when needed. Who cares how many rpm my fan is spinning?
Can I just add my 2penny worth....I have just replaced my antec fans with Yate loon and added a zalmann MFC1+ controller....they have made a big difference in noise...so much quieter, but I wish I went with D12SH to give that extra oomph when needed yet still ok and quiet when not, so maybe think about getting the biggest shifting fan you can get and use the fan controller
Yeah, I've got Speedfan installed and as long as I just make sure the temperatures are fine then I don't think I need to go overboard on it.
I think if I had more than two fans that I needed to control, that ability would be handy but with only two I think the ability to just adjust the voltage is fine.
Good point, I'll get the D12SH ones instead.
Yate Loons shift more cfm than D12SH, it's just D12SH are meant to be quieter but not much in it tbh.
See this thread for a full and frank cfm/silence discussion:
http://forums.overclockers.co.uk/showthread.php?t=17882906
Sorry greebo should have made myself clearer I have fitted Yate loon D12SM but now wished I fitted Yate Loon D12SH :p
But now looking at the deltas and boy do they shift some air; Delta EFB1212VH 120x25mm
Yeah but have you heard them? Jet engine!
I would rather have a Yate loon, Noctua, Xilence, Asaka Amber, Sharkoon which shifts a decent amount of air quietly!
And if using as case fans you just needs a nice steady flow of cool air circulating through the case not a car test wind tunnel!
Also my mistake, I thought the D12SH were the Noctua ones, not the different Yate Loon.
You will be limited by the thermal load that the heatsink can cope with before a fan like that would max out.. at 4ghz I notice no difference in temps when running my delta's at 3000 or 3500+ rpm simply because my TRUE can not move the heat fast enough... done a comparison on it a while back is on here somewhere with graphs and everything! This is why at high clock speeds you notice little to no difference between having 1 and 2 delta's on a heatsink
Edit:
Here
I have one somewhere @ 4ghz which shows even less difference at higher RPM
Thats a nice bit of info Pneumonic, are you still running that rig???
I agree with what you have done, when you need to shift some air due to temps then you turn them up, thats why I should have got the SH as oppose to the SM !!
Better to have too much than not enough, especially when you have fitted a fan controller
Would you also recommend the YL D12SH's or would they be overkill on a stock clocked system?
No, not really. If the price difference isn't much then why not. You will have a nice cool flow of air through your system and you may at some point not have a system at stock and the fans will last for years (I have had mine 4 years now in 3 computers) so best to think ahead always ;)
Awesome, I'll get them ordered asap.
Thanks for all your help guys
