Case fans for Fractal Design Node 804
10 Jan 2009
Building unraid server in Node 804 case which will have no GPU in it. Could anybody recommend me some case fans please, quite but still effective if possible. Case does have its own controller with low, medium and hight settings.
If the system isn't going to use much power, then I suspect any cheap case fan run at minimum speeds would be enough.
