CASE FANS - help!
16 May 2009
I have 2 case fans, none of which are connected to a fan controller.
Is there anyway to turn off the fans without unplugging them or any software to control their speeds etc?
Thanks in advance! :)
The only other way without a controller is to hook them up to your motherboard if both the fan and the board have 4 pin connectors. Then you can set the temperature range/speed for it to turn on in the BIOS.
