- 9 May 2009
Hi all,
I am after 2 case fans one 120mm and one 140mm for a NZXT H510i case as exhaust fans. I have been looking at the Noctua NF-S12A & NF-A14 PWM Chromax fans, are these any good.
I have not bought fans in years as this is my forst build in about 10 years and bought a H510i case and read that this case is a waste of time with intakes and needs good echaust fans. The fasn i was looking at are the Noctua but are there any better fans or are these about the best you can get, I was also looking at the NF-F12 but was told there more a heatsink or rad fan than a case fan and not to use them.
Now i am not to bothered about RGB fans but i am thinking about it as i never had a Window case before but not to sure if RGB fans are any good or better than the Noctua.
so the question is what do i need to look for can, any help would be great
thanks
thanks
