Case Fans - How many and where?
19 May 2004
Horsham, West Sussex
I have an AMD64 3700+ which is overclocked in quite an old case.
The case is quite nice but has limited cooling options (because of its age) so I am going to replace it.
Cases that I have been looking at have 3 positions for fans - front, rear and side.
My first question is whether a side fan is useful or do they just apply to Intel CPUs?
My second question is airlow direction. I assume that the front takes air into the computer and the rear takes air out of it. But what about the side fan - in or out?
Thanks for the help.
Cheers,
Nigel
Side fans are often good as they direct cool air into the GPU area though if you have a case with good airflow this is less of an issue.
I always set fans as:
front - in
side - in
top - out
rear - out
AD
side fans can be down to the setup some work betting blowing in some sucking out so try both and see how it affects you're temps.
