- 25 Nov 2011
- The KOP
Hello the case I will be buying is corsair carbide 500r. Witch comes with 4 fans two in-take front a big 200 in-take side and one 120 at the back.
Now I will be adding a corsair H80, witch is recommended to be setup as in-take.
That means every fan in case will be setup has in-take lol on this case can you turn the Big side 200 and set it up has an out-take.
What would uses do with the fans in that setup?
Thanks
Thanks
