- 27 Apr 2024
- The Cotswolds
So I bought this PC here a while back and from the start I found the cooling fans to be extremely noisy which I traced to the AIO pump not spinning up properly when plugged into the CPU Opt header and a large amount of negative pressure within the case as a result of all the fans sucking air out. I've fixed the pump by plugging it into the AIO Pump header and recently I've taken out the rear fan which has helped with temperatures enormously. Seems that the fans were fighting each other and all the GPU heat was going straight up into the AIO rad but now I've got a decent stream of warm air from the front fans and a much cooler AIO rad.
The question is what to do about the back where the fan was. I don't think Kolink make a reverse version of the installed fans but the gap looks quite big with nothing there. Does anyone know of a suitable reverse fan that would look good in that space so I can set up a push pull system?
