Very strange. The norm is the other way round because logic dictates that your psu and usually your gpu is pumping loads of hot air out of the back so you don't want your air intake to be coming from that area and also, in general, the back of peoples cases tend to be cramped, against walls, in corners so the air will be warmer to be used as an intake.
However, not familiar with you case and there may will be good reason with airflow inside it as to why it's routed like.
