- 12 Aug 2011
- Newport - South Wales
I have two 80mm fans installed in my case but had no way to power them since my motherboard only have one fan slot which was already in use.
I then bought a 4 Pin Molex to 3 Pin fan cable. When I plugged it in, it didn't work.
I knew it wasn't the fans since they work when I plug it into the motherboard. I thought it might be the molex from the PSU, but when I used the molex powering my front fan it still didn't work.
I then thought it was a fault with the adapter, so I got a replacement and that didn't work. I then bought another adapter off a different seller on eBay and that still doesn't work. Why is this?
These are the ones I bought :
http://www.ebay.co.uk/itm/160615213769#ht_867wt_905
http://www.ebay.co.uk/itm/Molex-4-P...uting_CablesConnectors_RL&hash=item19c685a40e
Thanks for any help.
